Print Composer Re: [Qgis-user] Bugs, release of 1.7 and release of 1.7 as beta
Andreas Neumann
a.neumann at carto.net
Tue Jun 7 11:47:04 PDT 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
> Two for grids:
> 1. At times I'd like some options other than solid lines or crosses for grid lines. Probably dashed or dotted lines would do.
this would be probably easy to do.
> 2. At other times I'd really like an easier way to put up grids in two different projections. I know Micha has some instructions on doing this (http://www.surfaces.co.il/?p=616) but it would be really cool to be able to do it inside the print composer.
probably more work. If you seriously need this, you can ask Marco for an
offer/estimate how many hours of work. Other people asked for this
feature as well. So maybe an opportunity to combine financial resources
for implementing it?
> 3. I'm noticing that when I browse to a folder with images, the path is reported with \ in the opposite direction to the default set, causing QGIS to loose my added directory. Can anyone else using Windows osgeo install confirm this?
don't have the Windows version at hand currently.
> 4. I'm also interested in the multicolumn feature.
the Swiss QGIS users discussed this already. I have to check tomorrow if
this is already in the pipeline (if we already have a sponsor). Will let
you know tomorrow.
Andreas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJN7nIkAAoJELiCsGDopvBCpP0H/3VJ5uXzmqsCVZsoGXKPAR0e
6g3BBKp5GdIR/xj5k82v2wqA3mxPK0JWpnd9lr9NDxsvGYhiJCuRI8xrpYg/B41V
rMeE7SOmTi9T78uPmWEgdLMacfNEzQ555edinDLi1AL4Vk/8mo0PwV9RUOmgFLBK
zvAJyE8GTDSf5Pm/0r1Ra8+wBg2Fhagwpbd9LGhj4afvT78nZ4Supwiyew+WclEg
5qbMorFVuAMuE9SKseAKbOP46DUz8sTtkYdLygrorpFFz5LkfXMUCOsYbIRPi+Nn
ng4C3fO2LvBbh0HaCMojA0tvxMf5ViM/d1flSBRheeQz7tETyVcfwIxCT9mBmmc=
=8u4H
-----END PGP SIGNATURE-----
