[Qgis-user] Re: [Qgis-developer] Re: Mac Snow Leopard - QGIS Symbology
Mars Sjoden aurorageomatics at gmail.com
Sat Jun 11 23:52:54 PDT 2011
Hello William,
I tested the latest QGIS  from git master
I was able to do one Categorized Symbology Style of 14 to a shapefile with
81007 records.
The next Symbology Style was Simple polygon layer with a fill colour change
which caused QGIS to hard crash.
So I'll keep using  QGIS for geoprocessing but look forward to this
symbology fix for mac.
Thanks!
mars
On Sat, May 28, 2011 at 8:10 PM, William Kyngesburye
<woklist at kyngchaos.com>wrote:
> Mars, can you try current git master?  I made a couple changes to the GDAL
> and GEOS framework detection.  Maybe not related, but it's worth a try, and
> there have been other changes in the past couple weeks.  I couldn't get QGIS
> to crash, but it's always been hard for me to verify this bug.
> On May 19, 2011, at 7:28 PM, Mars Sjoden wrote:
> > I have also found that changing only transparency will cause QGIS to
> crash also.
> > Essentially I am finding that at some point, when I go to change a Layers
> symbol, (line weight, colour, polygon fill, point symbol) QGIS will crash.
> > Sometimes it is on the first try, sometimes it takes 4-5 tries.
> > While I have found various work-a-rounds that reduce the chances of QGIS
> crashing on a symbology change for a layer, I have not found any specific
> way to make it reliable, eventually QGIS crashes.
> > I just tested on 1.8.0-Trunk (c7aed57)
> > Simply opening Layer Properties/Style (tab) and clicking Cancel/OK/Apply
> will crash QGIS now.
> > mars
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "History is an illusion caused by the passage of time, and time is an
> illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110611/72aea2b8/attachment.html>
