[Qgis-user] Default QGIS project file to open plugins automatically
Markus Weidenbach landconsult at freenet.de
Fri Jun 17 02:19:34 PDT 2011
Hi Giovanni and Andreas,
thanks for your help, but still, for some strange reason only about 2/3
of the activated plugins (or extensions, I am running the German version
and I am not sure about the English term used) remain active when I
start a new project or when I re-start the previous one.
Many plugins I activated before and which I wanted to use permanently, I
had to activate again in the QGIS Extension/Plugins Manager Window, such
as the 1-Band Raster Colour Table, the QGIS File Browser, the Raster
Calculator, the Import Project, MMQgis, the OTB Plugin and many others.
In the Extension Manager Window the location of the Plugin Directory is
indicated as C:\OSGEO4W\apps\qgis\plugins but in fact there are only a
few *.dll files of all activated plugins. Other locations of the python
plugins, which remain active, are C:\OSGeo4W\apps\qgis\python\plugins.
And in the directory C:\Users\markus\.qgis\python\plugins you can find
ALL de-activated python plugins PLUS many activated python plugins.
Strange, but could the paths to the plugin directories be the reason?
Andreas, I checked version 1.6 and unfortunately there is no startup
parameter called --optionspath, a very useful feature, that might be
implemented in future versions.
Regards,
Markus
Am 16.06.2011 12:25, schrieb Giovanni Manghi:
> Hi Markus,
> I don't know if I understand correctly your problem, but the
> installed/activated plugins have nothing to do with qgis projects.
> When you re-open qgis with a blank project you should see all the
> plugins you have installed/activated the last time you used the program.
> cheers
> -- Giovanni --
> On Thu, 2011-06-16 at 12:19 +0200, Markus Weidenbach wrote:
>> Dear List,
>> is there a way to create sth. like a *.qgis default project file which
>> activates automatically all plugins I´d like to have when I start a new
>> project (or restart an old one with previously activated plugins)?
>> So far, I have to open all plugins, such as the QGIS File Browser,
>> manually, all the time again. It seems that the information of an
>> activated plugin is not being written in the qgis project file. This
>> problem does not concern the official plugins already implemented into
>> the latest qgis version, but all plugins downloaded later on.
>> I am using QGIS 1.6 on Win 7, Prof. 64 bit
>> All hints are welcome.
>> Markus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
