[Qgis-user] Raster -> Merge (gdal_merge) failure
Giovanni Manghi
giovanni.manghi at gmail.com
Sun Jun 19 04:14:05 PDT 2011
> Giovanni, I've never needed to set the path to Gdal before.
just needed for win/standalone
> Here I see that GdalTools (together with some
> other plugins) is already installed. It's not, of course, and what's
> more the options to upgrade, reinstall or uninstall it are greyed-out.
> So now I really am in Queer Street.
you need to activate it in the plugin manager.
> So where do I go from here, Guys? There seems to be some residual
> memory of a previous installation, somewhere.
as I said, if it fails from the command line you should look for the
problem in your gdal installation, not qgis.
cheers
-- Giovanni --
