[Qgis-user] installing 1.7 standalone Win XP: Couldn't load PyQGIS., Python support will be disabled.
Janneke Qgis janneke.qgis at gmail.com
Thu Jun 23 01:16:00 PDT 2011
Thanks, Milo, I'll give it a try. I need the python bindings. It looks a
bit daunting though, last time I tried building things I got completely
stuck.
I'm a bit surprised that the standalone installer doesn't come with the
corresponding python sip - I hoped it would've worked out of the box. Is
it supposed to?
greetings,
Janneke
On 23/06/2011 11:02, Milo van der Linden wrote:
> Hello Janneke,
> I think I remember that qGIS can run without pyQGIS, so you should be
> good on "regular" functionality with qGIS.
> However, for python support you need a more recent version of python
> sip. Instructions for installing that can be found here:
> http://www.riverbankcomputing.co.uk/static/Docs/sip4/installation.html
> Good luck!
> Milo van der Linden
> 2011/6/23 Janneke Qgis<janneke.qgis at gmail.com>:
>> Dear all,
>> I've just tried installing the standalone version of Qgis 1.7 on XP, and
>> after starting the program I get the following error message:
>> Traceback (most recent call last):
>>   File "", line 1, in
>> RuntimeError: the sip module implements API v5.0 but the qgis.core
>> module requires API v8.1
>> Python version:
>> 2.5.1 (r251:54863, Apr 18 2007, 08:51:08) [MSC v.1310 32 bit (Intel)]
>> QGIS version:
>> 1.7.0-Wroclaw 'Wroclaw', 63ecdd7
>> Python path:
>> ['C:/PROGRA~1/QUANTU~2/apps/qgis/./python', 'C:/Documents and
>> Settings/Admin/.qgis/python', 'C:/Documents and
>> Settings/Admin/.qgis/python/plugins',
>> 'C:/PROGRA~1/QUANTU~2/apps/qgis/./python/plugins', 'C:\\Program
>> Files\\ArcGIS\\bin', 'C:\\Qgis\\apps\\qgis\\python',
>> 'C:\\Qgis\\apps\\Python25\\Lib\\site-packages',
>> 'C:\\WINDOWS\\system32\\python25.zip',
>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\DLLs',
>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib',
>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\plat-win',
>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\lib-tk',
>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\qgis\\bin',
>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25',
>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\site-packages',
>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\site-packages\\win32',
>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\site-packages\\win32\\lib',
>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\site-packages\\Pythonwin',
>> 'C:\\PROGRA~1\\QUANTU~2\\apps\\Python25\\lib\\site-packages\\wx-2.8-msw-unicode']
>> Is there anything else I should install or set? I've also sent it to the
>> developer list yesterday.
>> greetings,
>> Janneke
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
