[Qgis-user] import floating point raster (*.flt)
Even Rouault
even.rouault at mines-paris.org
Mon Jun 27 02:40:10 PDT 2011
Selon Els Goossens <egoossens at avia-gis.be>:
> Hi list,
> I want to import a esri float raster (*.flt-format, 32 bit, floating point)
> into QGIS. QGIS imports this format as a 8 bit unsigned integer, resulting in
> wrong values (scaled between 0 and 255) and a modified extend (enlarged in
> both x and y direction).
Yeah, this issue has just been raised on gdal-dev mailing list. See
http://lists.osgeo.org/pipermail/gdal-dev/2011-June/029166.html for more details
and a workaround until GDAL 1.8.1 is released
> Is there a way to convert the *.flt format to a file format that can be
> imported into QGIS?
If you can use a version of GDAL < 1.8.0, you can gdal_translate it into a tif
for example.
> Many thanks,
> Els Goossens
> Qgis-user mailing list
