[Qgis-user] Incorrect Results in Buffer
Frederick Löbig frederick.loebig at live.de
Fri Mar 4 00:03:14 PST 2011
Hi there,
I have a problem using the buffer function in qGIS 1.6.0:
The situation: I have my project SRS set to EPSG:900913 (web mercator). As a layer I have a line-layer also with EPSG:900913 as a projection. The project-wide units are meters. I now want to add a 250m buffer around the lines so i click vector->geoprocessing tools->Buffer(s), select my line-layer, type in 250 for 250 meters, check dissolve buffer results ans set a filename. Then the buffer is created, but unfortunately, when I export the buffer as kml and check the buffer width in Google Earth it is around 150-160 meters, so far off my 250meters. I also checked the distance with the qGIS measurement-tool - same result.
The lines are located in London. I have tried to use simple WGS84 and the british nationale grind, but none of them worked.
This has to do something with differente base-ellipsoids I think, but I did not get to the bottom of the problem.
Could anybody please help me with this?
Frederick Löbig
Röderichstraße 59
60489 Frankfurt am Main
E:: Frederick.Loebig at grunsnid.de
P: +49 (0) 69 - 78 99 52 41
M: +49 (0) 174 - 70 89 296
Office:
euNetworks GmbH
Ludwig-Landmann-Straße 40560486 Frankfurt am MainP: +49 (0) 69 - 90 554 - 532
E: Frederick.Loebig at eunetworks.com
S: floebig
This email and any attachments may contain confidential and/or legally privileged information. If you are not the intended recipient, please delete the email without reading it and notify the sender.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110304/28a83d1d/attachment.html>
