[Qgis-user] font settings on mac (Fwd: Comments on the QGIS map composer)
William Kyngesburye
woklist at kyngchaos.com
Mon Mar 14 11:17:50 PDT 2011
This is fixed in SVN. It requires at least Qt Cocoa 4.7.1 since it was a Qt bug that ignored a flag passed to the font dialog (Qt Carbon is not affected, so the Mac dialog is used then). Note that using the Qt font dialog is really a workaround because there are still (apparently) bugs in the native font dialog. Also, while all fonts can be selected, some still don't display correctly. And some odd font styles don't even show up in the choices.
On Mar 14, 2011, at 6:51 AM, maning sambale wrote:
> Reposting the issue below.
> I'm using qgis 1.6 0n mac 10.5 and instead of the usual font window, I
> see the mac font window is used in the map composer (see the sample
> image below). I tried changing the font for several map elements
> (text window, grid font size) but I can't change it to the default
> "Lucida Grande" size "13"
> ---------- Forwarded message ----------
> From: maning sambale <emmanuel.sambale at gmail.com>
> 4. On a mac, Scale font options uses the mac font option window
> instead of the usual QGIS font option window (see image link).
> http://farm5.static.flickr.com/4036/5074097761_3d6af0fef4_z.jpg
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Mon Dieu! but they are all alike. Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings. And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
