[Qgis-user] lines to polygons
Duarte Carreira DCarreira at edia.pt
Fri Mar 18 11:07:14 PDT 2011
Ok, got it.
Thanks for your reply.
Duarte
-----Mensagem original-----
De: Carson Farmer [mailto:carson.farmer at gmail.com]
Enviada: sexta-feira, 18 de Março de 2011 17:10
Para: Duarte Carreira
Cc: qgis-user at lists.osgeo.org
Assunto: Re: [Qgis-user] lines to polygons
This tool essentially expects you to have your data in the format
produced by polygons to lines. In other words, where each line is it's
own polygon boundary, and as far as I can remember, the line should be
closed (i.e. starts and ends at the same point).
Carson
On Fri, Mar 18, 2011 at 1:00 PM, Duarte Carreira <DCarreira at edia.pt> wrote:
> Hi.
> I'm trying to use this function and need some help. What are the
> requirements for this tool? Does it work for a single closed line? Does it
> work with several connected lines that make a ring? Does it work with
> spaghetti lines?
> Thanks,
> Duarte
> Qgis-user mailing list
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation
National University of Ireland, Maynooth,
http://www.carsonfarmer.com/
