[Qgis-user] font settings on mac (Fwd: Comments on the QGIS map composer)
maning sambale emmanuel.sambale at gmail.com
Wed Mar 30 22:59:58 PDT 2011
I installed the latest dev build (Qgis-r15622-leo.dmg) and all the
necessary frameworks, I get the following errors:
Process:         Qgis [4308]
Path:            /Applications/Qgis.app/Contents/MacOS/Qgis
Identifier:      Qgis
Version:         ??? (???)
Code Type:       X86 (Native)
Parent Process:  bash [1548]
Interval Since Last Report:          880369 sec
Crashes Since Last Report:           57
Per-App Interval Since Last Report:  0 sec
Per-App Crashes Since Last Report:   2
Date/Time:       2011-03-31 13:56:33.914 +0800
OS Version:      Mac OS X 10.5.8 (9L31a)
Report Version:  6
Anonymous UUID:  4AD9E39D-E433-4A1F-9AA0-F43C2F16A971
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread:  0
Dyld Error Message:
  Library not loaded: @loader_path/libintl.dylib
  Referenced from: /Applications/Qgis.app/Contents/MacOS/lib/libpq.dylib
  Reason: no suitable image found.  Did find:
	/Applications/Qgis.app/Contents/MacOS/lib/libintl.dylib: unknown
required load command 0x80000022
	/Applications/QGIS.app/Contents/MacOS/lib/libintl.dylib: unknown
On Tue, Mar 15, 2011 at 9:27 PM, William Kyngesburye
<woklist at kyngchaos.com> wrote:
> My last dev build includes that.
> On Mar 14, 2011, at 11:27 PM, maning sambale wrote:
>> Dear William,
>> Thanks for the fix.  Is this available now in your website?
>> As I need to quickly produce some layout, I had to edit by hand the
>> qpt files in a text editor (ugh!).  While this works in many of my
>> fontsize changes, when I tried reloading the qpt through the map
>> composer, my custom labels in the legend box (group text and item text
>> ) was not recognized.  Instead, it reverts back to the default legend
>> layout.
>> The changes that were not included are not the font size but the text
>> labels I modified within the Map composer.  I normally, move the layer
>> label into the item label.
>> Anyway, happy to point out that you can edit layout settings via text editor. :)
>> On Tue, Mar 15, 2011 at 2:17 AM, William Kyngesburye
>>> This is fixed in SVN.  It requires at least Qt Cocoa 4.7.1 since it was a Qt bug that ignored a flag passed to the font dialog (Qt Carbon is not affected, so the Mac dialog is used then).  Note that using the Qt font dialog is really a workaround because there are still (apparently) bugs in the native font dialog.  Also, while all fonts can be selected, some still don't display correctly.  And some odd font styles don't even show up in the choices.
>>> On Mar 14, 2011, at 6:51 AM, maning sambale wrote:
>>>> Reposting the issue below.
>>>> I'm using qgis 1.6 0n mac 10.5 and instead of the usual font window, I
>>>> see the mac font window is used in the map composer  (see the sample
>>>> image below).  I tried changing the font for several map elements
>>>> (text window, grid font size) but I can't change it to the default
>>>> "Lucida Grande" size "13"
>>>> ---------- Forwarded message ----------
>>>> From: maning sambale <emmanuel.sambale at gmail.com>
>>>> 4. On a mac, Scale font options uses the mac font option window
>>>> instead of the usual QGIS font option window (see image link).
>>>> http://farm5.static.flickr.com/4036/5074097761_3d6af0fef4_z.jpg
>>>> cheers,
>>>> maning
>>>> "Freedom is still the most radical idea of all" -N.Branden
>>>> wiki: http://esambale.wikispaces.com/
>>>> blog: http://epsg4253.wordpress.com/
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> "Mon Dieu! but they are all alike.  Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings.  And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
>>> - the wisdom of Tarzan
>> cheers,
>> maning
> "This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
cheers,
maning
