[Qgis-user] Export shapefiles to kml
Amedeo Fadini fame at libero.it
Tue May 3 02:18:27 PDT 2011
On Tue, May 3, 2011 at 11:03 AM, Saber <razmjooeis at faunalia.co.uk> wrote:
> You can right-click on your layer and save it as kml...if you consider
> that as a direct method :)
You can also use the ogr2ogr command from osgeo4w shell, useful if you need
to process more file at once with a batch script (in windows) or a shell
script.
amefad
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110503/0b2caccf/attachment.html>
