[Qgis-user] RE: Qgis-user Digest, Vol 63, Issue 9
Alister Hood alister.hood at synergine.com
Fri May 6 03:31:31 PDT 2011
Depending on what you mean by "analysis of flow of water as from an image of satellite" you might also want to try BASINS/Mapwindow.
I don't think these do what you want, but I could be wrong.  If they do, they are more user friendly than Grass or even Saga.
Regards,
Alister
Date: Thu, 05 May 2011 19:35:16 +0100
From: Saber Razmjooei <razmjooeis at faunalia.co.uk>
Subject: Re: [Qgis-user] information
To: MONJARAZ <fer_monja at prodigy.net.mx>
Cc: Qgis-user at lists.osgeo.org
Message-ID: <1304620516.2002.38.camel at ioio>
Content-Type: text/plain; charset="UTF-8"
Hi there
You can use GRASS within Quantum GIS.
GRASS has got several hydrological/hydraulic model flow routes through
Digital Terrain Model.
Here is a link to some of the simulation modules within GRASS:
http://grass.fbk.eu/intro/modelintegration.html
If you want detail simulation tool to calculate depth, velocity, hazard,
etc based on shallow water equations, you can use AnuGA:
http://datamining.anu.edu.au/
We wrote a plugin for mesh generation within QGIS, so that you can use
QGIS as pre-processing tool:
http://sourceforge.net/projects/anuga-gai/
Hope that helps
Saber
On Thu, 2011-05-05 at 13:01 -0500, MONJARAZ wrote:
> Good morning
> I am new in qgis use and besides bad with the English language, I want
> to know if somebody can help me for knowledge like doing the analysis
> of flow of water as from an image of satellite.
> Thanks
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110506/ef4008f9/attachment.html>
