[Qgis-user] Problem with creating georeferenced DXF file in QGis
Saber Razmjooei razmjooeis at faunalia.co.uk
Sun May 8 03:12:56 PDT 2011
Do you know the original coordinate system of your DXF.
If it has been prepared in AutoCAD, you need to open it there and  check
your UCS.
You can use "align" command in AutoCAD to scale and move the drawing to
the right place.
Some of the CAD drawings are drawn in local UCS....and don't care about
projection/real location...for them the earth always remains flat!
Saber
On Sat, 2011-05-07 at 08:06 +0200, Christophe TUFFERY wrote:
> Hi,
> I spent a lot of time yesterday to finally find that OGR library
> couldn't allow to create georeferenced DXF file but only DXF file
> without any georeferencing system. It's mentioned here :
> http://www.gdal.org/ogr/ogr_formats.html
> Does someone know a plugin or any solution that allows to create and
> modify georeferenced DXF file within QGis ?
> Of course I know DXF2shp plugin but it allows only to export shape
> file from DXF file witout georeferencing system.
> I also used Grass but I didn't succeed in getting a correct file. It
> adds a step by using another software and results are not able to be
> anymore imported in QGis.
> Thank you by advance for tour answers.
> Christophe TUFFERY
> Ingénieur de recherche
> Institut national de recherches archéologiques préventives
> Direction Scientifique et Technique / Service Méthodes et Qualité
> 7, rue de Madrid 75008 PARIS
> Tél.: 01-40-08-81-03 / Fax : 01-43-87-18-73
> Courriel : christophe.tuffery at inrap.fr
> Site Web : www.inrap.fr
> Qgis-user mailing list
