[Qgis-user] how to display polygons from qgis in google earth?
M.E.Dodd m.e.dodd at open.ac.uk
Tue May 10 02:55:23 PDT 2011
No this does not work, it simply gives all positions as lat 1 degree long 1 degree i.e. plots all the data in the middle of the ocean.
However if you convert from ordnance survey to lat long outside qgis then bring the data back into qgis telling it that its wgs84 then create the kml then it does work.  This is fine for points, but I can't see how to do it for polygons or lines.
From: Frank Sokolic [mailto:sokolic at worldonline.co.za]
Sent: 10 May 2011 09:52
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] how to display polygons from qgis in google earth?
You do this from within QGIS: right-click on the layer name in the Table of Contents and  choose the 'Save as' option. Then specify the format as 'Keyhole Markup Language' and the CRS as wgs84.
Frank.
On 2011/05/10 10:19, M.E.Dodd wrote:
Polygons created in qgis in osgb 1936 but want to display in google earth, how best to go about this.  With points its straightforward to convert from osgb1936 to wgs84 using external converter then produce a kml in qgis but don't know how to do it with shapefiles.
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
The Open University is incorporated by Royal Charter (RC 000391), an exempt charity in England & Wales and a charity registered in Scotland (SC 038302).
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110510/e5246463/attachment.html>
