[Qgis-user] ugly results with new symbology: how to improve them?
Paolo Cavallini cavallini at faunalia.it
Wed May 11 01:16:46 PDT 2011
Il 10/05/2011 19:46, Mayeul Kauffmann ha scritto:
> Hi Paolo,
>  I would just make everything round (cap and join) but then maybe
> problem with the offset.
Yes, I think the offset is the culprit here.
> You also need symbol levels ON on because you have several roads.
I think this is the point, but I do not quite understand how it works.
> Your qml looks almost perfect by me (see attachment), so if the above s
> does not work, I can help more but need a sample file (your scale is
> strange: "30 000 gradi"???)
I did not care about projection, it was just a quick snapshot.
All
Paolo Cavallini: http://www.faunalia.it/pc
