[Qgis-user] Problem with EPSG
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Wed May 11 21:17:57 PDT 2011
Hi Hugo
This usually happens if you have several conflicting versions of the qgis
libraries (libqgis_gui.so, libqgis_core.so etc.). Removing the old ones helps
in most cases.
Regards,
Marco
Am Mittwoch, 11. Mai 2011, 23.32:10 schrieb Hugo:
> Hello all,
> Is there anything wrong with using gdal 1.8 with qgis? I'm asking this
> because i've updated gdal from 1.7 to 1.8 today and when i open a project
> and try to set the base map's SRS there are no SRS (geographic and
> projected) at all. When using gdal through shell there are no problems when
> defining EPSG parameters. I'm using Ubuntu 10.10 64 bits. Any hint on how
> to solve this??
> Thanks in advance.
> Best regards,
> Hugo
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstr. 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
