[Qgis-user] Data on Google earth
Giovanni Manghi giovanni.manghi at gmail.com
Wed May 18 00:46:41 PDT 2011
your shape is missing the .prj so, unless you have changed the qgis
options about how to handle this situation, probably the vector was
given the wrong CRS (WGS84 by default). Change it manually in the vector
properties and eventually add the prj file with the proper tool in the
vector menu. Be sure also to enable on the fly reprojection.
cheers
-- Giovanni --
On Wed, 2011-05-18 at 12:41 +0530, subbu sravan wrote:
> Good afternoon one and all.I am using QGIS 1.6. I have data for
> rajahmundry (Andhrapradesh, IND).  when i overlaid on google earth
> it's not exactly matching with satellite image.It's actual SRID/EPSG
> code is 32644 but to overlay on google earth i changed it into 900913.
> But it is overlaid some where.Can any body know how to solve this
> problem please help me.Here i am attaching the rajahmundry data for
> your reference.
> With regards ,
> Subhakar Babu Battula.
> Qgis-user mailing list
