[Qgis-user] finding xy values for txt/dbf table
Saber
razmjooeis at faunalia.co.uk
Fri May 20 04:32:10 PDT 2011
You can digitize the points each with a unique ID similar to your
dbf/txt/excel.
Under Vector > Geometry Tools > Export/Add geometry.
You can then join the 2 table either in QGIS (join under Properties > Join
in 1.7) or in your favorite spreadsheet application (using vlookup
function for example).
Cheers
Saber
> Hi List,
> given a (txt/excel/dbf) table with data and two empty x,y columns in it
> given that a user based on a record of that data can point on a map
> where a record is located (either because there is some location
> description in the record, OR because there is an old scanned map
> available with numbers on it)
> what would be the easiest way to fill the x,y columns?
> a plugin or making a shape first and then make a txt/dbf from that?
> other idea's?
> Thanks,
> Richard Duivenvoorde
> Qgis-user mailing list
