[Qgis-user] RE: manageR doesn't work well
Maxime demers burton.1 at sympatico.ca
Thu May 26 21:47:53 PDT 2011
I have tested manageR on Ubuntu Gnome with QGIS 1.6 and R 2.11.1 and now the same shapefile that I was testing can be loaded. Now, I can perform some analysis on it. Is it because I was on Windows 7 that manageR was not working?
I still have an issue with manageR on Ubuntu. I cant load the shapefile with the option Import layer from canvas, and receive this error message:
Error in `[.data.frame`(data, match.ID[1]) : undefined columns selected
When I load the data with the option Import layer attribute it seems to work. Someone have an idea why the first option is not working? Anybody has successfully used manageR in a Windows 7 environment?
Thank you for your help,Maxime
> Date: Mon, 23 May 2011 17:22:31 +0100
> Subject: Re: [Qgis-user] RE: manageR doesn't work well
> From: carson.farmer at gmail.com
> To: burton.1 at sympatico.ca
> CC: qgis-user at lists.osgeo.org
> > I added R folder in the PATH environment variable but its not helping me
> > with my problem. Actually, manageR can be loader correctly in QGIS but when
> > I try to import a shapefile with the tool Import Layer from Canvas, I cannot
> > perform analysis on this data. It seems manageR cannot load the data which
> > is a simple polygon shapefile with an attribute table of strings and
> > numbers. When I type ls() or objects() in manageR I got the awnser
> > character(0) which means there is no variable loaded.
> > Im on Windows 7 32bit, QGIS 1.7.0 R 2.11.0 and Rpy2 2.0.3-1
> > Anybody have successfuly performed an analysis on a shapefile with manageR ?
> Lots of people have, so it is possible ;-) Did you check that both the
> sp and rgdal packages were installed as I mentioned before?
> What happens if you type something like the following into the manageR console:
> > library(rgdal)
> > layer <- readOGR("C:\path\to\your\layer.shp", layer="shape")
> also, see ?readOGR to make sure your arguments are correct.
> Alternatively, you can use the "Analysis > Spatial operations > Load
> OGR data" menu if you like.
> Carson
> > ________________________________
> > Date: Mon, 23 May 2011 02:42:11 -0700
> > From: [hidden email]
> > To: [hidden email]
> > Subject: RE: manageR doesn't work well
> > Hi,
> > a very common source of problems with R and QGIS is not having the
> > "bin" folder of C:\Program Files\R-x.y in your PATH environment
> > variable. It is necessary and not created by R installation
> > automatically.
> > Vaclav
> > 2011/5/22 Carson Farmer <[hidden email]>:
> >> hmm, Ok, well the only other thing I can think of is that you might
> >> need to install the following packages:
> >> install.packages(c("sp", "rgdal"))
> >> Carson
> >> On Sun, May 22, 2011 at 3:22 PM, burton449 <[hidden email]> wrote:
> >>> Hi Carson,
> >>> Sorry, my mistake, I use R 2.11.0 because in this version the executable
> >>> are
> >>> stored in a subdirectory that rpy2 can read. Newer version of R its not
> >>> working with rpy2. I will try your trick to change the code in the
> >>> __init__.py but I dont think it would solve my problem. Actually manageR
> >>> is
> >>> loading in QGIS but its not working properly.
> >>> Thank you
> >>> Maxime
> >>> Date: Sun, 22 May 2011 06:11:10 -0700
> >>> To: [hidden email]
> >>> Subject: Re: manageR doesn't work well
> >>> Hi Maxime,
> >>>> Im using manageR 1.0, QGIS 1.7 and 1.6 and R 1.11.0 on Windows 7
> >>> Are you sure you're using R 1.11.0? That's a pretty old version! Also,
> >>> which version of rpy2 are you using? Furthermore, I attach an email
> >>> from another manageR using with a possible solution for Windows 7
> >>> issues:
> >>> I had a problem getting ManageR to run on QGIS 1.60 (OSGeoW4 install)
> >>> with R-2.12.1 (32 bit) on Windows 7 64 bit systems. Rpy2 complained
> >>> about not finding R.dll.
> >>> Newer versions of R place the executable files in a new subdirectory,
> >>> i386, below the bin directory on Windows 7 systems.
> >>> After searching the net for a while, I finally found the following
> >>> post, which seems to fix the problem:
> >>> http://www.mail-archive.com/rpy-list@.../msg02779.html
> >>>  Try adding these two lines to rinterface/__init__.py
> >>>     # Load the R dll using the explicit path
> >>>     # First try the bin dir:
> >>>     Rlib = os.path.join(R_HOME, 'bin', 'R.dll')
> >>>     # Try bin/i386 subdirectory seen in R 2.12.0  ## ADDED ##
> >>>     if not os.path.exists(Rlib):                ## ADDED ##
> >>>       Rlib = os.path.join(R_HOME, 'bin', 'i386', 'R.dll')  ## ADDED ##
> >>>     # Then the lib dir:
> >>>       Rlib = os.path.join(R_HOME, 'lib', 'R.dll')
> >>>     # Otherwise fail out!
> >>>       raise RuntimeError("Unable to locate R.dll within %s" % R_HOME)
> >>> Hope that helps a bit,
> >>> Carson
> >>> Carson J. Q. Farmer
> >>> ISSP Doctoral Fellow
> >>> National Centre for Geocomputation
> >>> National University of Ireland, Maynooth,
> >>> http://www.carsonfarmer.com/
> >>> _______________________________________________
> >>> Qgis-user mailing list
> >>> [hidden email]
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> >>> If you reply to this email, your message will be added to the discussion
> >>> below:
> >>> http://osgeo-org.1803224.n2.nabble.com/manageR-doesn-t-work-well-tp5543144p6391395.html
> >>> To unsubscribe from manageR doesn't work well, click here.
> >>> View this message in context: RE: manageR doesn't work well
> >>> Sent from the qgis-user mailing list archive at Nabble.com.
> >>> [hidden email]
> >> Carson J. Q. Farmer
> >> [hidden email]
> > [hidden email]
> > below:
> > http://osgeo-org.1803224.n2.nabble.com/manageR-doesn-t-work-well-tp5543144p6393737.html
> > Qgis-user at lists.osgeo.org
> Carson J. Q. Farmer
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110527/2fd0b5d2/attachment.html>
