[Qgis-user] export as vector graphic
Andreas Neumann a.neumann at carto.net
Mon May 30 12:20:48 PDT 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Christof,
Vector export from the print composer to SVG or PDF should work. I
recommend to use the new symbology engine. That way point symbols are
kept as vectors in a PDF or SVG output. There are some problems that
should be resolved in future versions, but in general it works.
Also make sure you have a recent version (1.7).
Andreas
On 05/30/2011 07:19 PM, Christof Kluß wrote:
> Hi,
> is it possible to convert shapefiles into a vector format like SVG or
> PDF? Print and PDF plugin seem to convert the vector data to raster
> graphics.
> If not, is there another inexpensive tool that can? So we get scalable
> PDF files?
> tia
> Christof
> Qgis-user mailing list
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJN4+4QAAoJELiCsGDopvBCaswIAKpB+eqaeODpzN4dbJdhMfMv
qMI2fggjYXGaWdy76qhJHCSIbe819CPXcNZB93PZbkjt7wVjuEF+XywWApEI9JIx
OjWOaRL4XkBX+4+ZukP+dx5baBJtj0+cbwZVvd5RZuSctcVBzERYQHQljo17NzVf
xQ+UyCESnoVfQHKpuU5GFZp9TeMBOoBgZz+SU+PS3OKujbb5MmDSxbU9I4qtfB+O
/qND7Efwh2zW3IuBEtyKGgOImMmOV1f2PC0Y/uIt9hjUIepSoln5psdGWnKl0wma
pxH1Bf48cG+LIoERvDGW3xuqciBoVlzJCJubPmzfvS0G1wyVmSyxDNO+XZCDIlI=
=aHTv
-----END PGP SIGNATURE-----
