[Qgis-user] Re: Mac Snow Leopard - QGIS Symbology
Mars Sjoden aurorageomatics at gmail.com
Mon May 30 18:28:59 PDT 2011
Hello William,
thank you. I will give it a go once our flood situation is over and I
can gain access to the lab computers or even mine that have been dry
stored for now.
I would be very interested in knowing your Hardware and Software specs
you use. I Have heard from some Mac users how QGIS is very stable,
while others will use QGIS for a few minutes and find continous hard
crashes. Perhaps there is some sort of issue with Qt and certain
hardware/software combos?
thank You again,
Cheers
Mars
On Saturday, May 28, 2011, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Mars, can you try current git master?  I made a couple changes to the GDAL and GEOS framework detection.  Maybe not related, but it's worth a try, and there have been other changes in the past couple weeks.  I couldn't get QGIS to crash, but it's always been hard for me to verify this bug.
> On May 19, 2011, at 7:28 PM, Mars Sjoden wrote:
>> I have also found that changing only transparency will cause QGIS to crash also.
>> Essentially I am finding that at some point, when I go to change a Layers symbol, (line weight, colour, polygon fill, point symbol) QGIS will crash.
>> Sometimes it is on the first try, sometimes it takes 4-5 tries.
>> While I have found various work-a-rounds that reduce the chances of QGIS crashing on a symbology change for a layer, I have not found any specific way to make it reliable, eventually QGIS crashes.
>> I just tested on 1.8.0-Trunk (c7aed57)
>> Simply opening Layer Properties/Style (tab) and clicking Cancel/OK/Apply will crash QGIS now.
>> mars
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
