[Qgis-user] export as vector graphic
Alister Hood alister.hood at synergine.com
Tue May 31 03:42:09 PDT 2011
Hi everybody,
> Date: Tue, 31 May 2011 12:04:55 +0200
> From: Andreas Neumann <a.neumann at carto.net>
> Subject: Re: [Qgis-user] export as vector graphic
> To: Marco Hugentobler <marco.hugentobler at sourcepole.ch>
> Cc: qgis-user at lists.osgeo.org
> Message-ID: <8d2ae16abf3640208b252776c4e54d1e at carto.net>
> Content-Type: text/plain; charset=UTF-8; format=flowed
> > Oh, is this with the 'exportPDF' button (or pdfcreator). With
> > 'exportPDF', it
> > should be exported as vector, at least it does for me on Linux here.
>  printing through gdi/pdfcreator results in a rasterized PDF.
In my testing it creates a vector or a rasterized or a partly rasterized PDF, depending on what is on the composer layout.  See my comments and attachments in Trac in #3250.
>  Printing
>  through the exportPDF results in a very large PDF which cannot be loaded
>  by Inkscape and also SumatraPDF. AdobeReader opens it, but it takes
>  ages. I am not entirely sure if it is raster or vector. If I zoom in
>  very closely it looks pixelized. It almost seems like a multilayered
>  raster (each QGIS layer is a rasterized layer in the PDF).
Yes, I get a multilayer rasterized PDF.  There is at least one bug report which relates to this, too.
>  With Linux, all seems fine, either way. It stays as a vector with both
>  ways to generate a PDF.
>  Maybe some problem with the Windows qt version in user at the OSGeo
>  distribution?
>  Andreas
>  Andreas Neumann
>  Böschacherstrasse 10A
>  8624 Grüt (Gossau ZH)
>  Switzerland
Alister
