[Qgis-user] Plugins broken!
Alister Hood alister.hood at synergine.com
Mon Nov 7 21:00:02 PST 2011
Hi Daniel,
If there isn't a pre-built package for OSX it should still be possible to build from source, but I can't really help with that.
If you want to try it yourself you might want to look at https://github.com/polymeris/qgis/wiki/How-to-install-the-SAGA-Python-Bindings, although it doesn't cover OSX.
Also, note that it is generally best to reply to the mailing list, not just to an individual.  I'm copying the list back in.
> -----Original Message-----
> From: Daniel Alejandro Pacheco [mailto:danny__alejo at hotmail.com]
> Sent: Tuesday, 8 November 2011 5:21 p.m.
> To: Alister Hood
> Subject: Re: [Qgis-user] Plugins broken!
> Hi Alister, tks for your answer.
> I think that the problem is I work on Macintosh operating system! I looked
> everywhere, but I can't find how to install Saga Phyton bindings under
> Mac. I don´t know if it is possible. Maybe you know how to do it?
> Regards
> Daniel
> El 07/11/11 18:00, "Alister Hood" <alister.hood at synergine.com> escribió:
> >Hi Daniel,
> >What operating system are you using?  Windows?
> >1. This conversation should help with the profile plugins:
> >http://osgeo-org.1803224.n2.nabble.com/Profile-Tool-td6745484.html
> >2. On Windows QGIS is still built with Python 2.5, but the latest
> >versions of the Saga python bindings are for Python 2.6 or 2.7
> >You may have success using a slightly old version:
> >http://sourceforge.net/projects/saga-gis/files/SAGA%20-%202.0/SAGA%202.0
> >.5/saga_2.0.5_bin_mswvc9.zip/download and
> >.5/saga_2.0.5_python25_mswvc.zip/download
> >To install the python bindings, open the zip, go into the subfolder
> >Python25\Lib\site-packages\, and extract its contents to
> >C:\osgeo4w\apps\Python25\Lib\site-packages (or similar).
> >I was able to run `import saga_api` at a Python prompt, so it seems the
> >Python bindings were working, but when I tried to turn the processing
> >framework panel on in QGIS I got some error about something not being a
> >grid.  I lost interest at about this point - not sure if the problem is
> >with the QGIS saga plugin or what.  Note that I only tried with QGIS
> >trunk.
> >Alister
> >> Date: Mon, 7 Nov 2011 14:30:18 -0500
> >> From: Daniel Alejandro Pacheco <danny__alejo at hotmail.com>
> >> Subject: [Qgis-user] Plugins broken!
> >> To: <qgis-user at lists.osgeo.org>
> >> Message-ID: <BLU0-SMTP151BE4726F90075FFC55A94DED90 at phx.gbl>
> >> Content-Type: text/plain; charset="us-ascii"
> >> Hi, my name is Daniel Alejandro, I'm a ecuadorian university student
> >and I
> >> need help.
> >> Many times I tried to install a very essentials plugins for me.
> >> I really need the SAGA MODULE INTERFACE, PROFILE, PROFILE FROM LINE,
> >but
> >> always when I try to install them, appears a error message "THE PLUGIN
> >IS
> >> BROKEN". I dont know how fix the problem, and I really need the
> >plugins.
> >> Any help for try to fix this trouble is welcome.
> >> Tks a lot!
> >> Regards
> >> D.A.
