[Qgis-user] Announcing the Rectangles ovals digitizing plugin - not working in Ubuntu
Saber Razmjooei razmjooeis at faunalia.co.uk
Wed Nov 9 02:28:20 PST 2011
Select a shape from the toolbar, in the canvas: click and drag.
Cheers
Saber
On Wed, 2011-11-09 at 21:26 +1100, Noli Sicad wrote:
> OK. I saw it. Thanks.
> I am now in Mac OS X.
> My laptop is triple boot :-).
> I toggled the Pencil icon - edit, yet I could not make to change or
> use the defaullt rectangle to draw.
> How do you use this plugin?
> Noli
> On 11/9/11, Saber Razmjooei <razmjooeis at faunalia.co.uk> wrote:
> > Works for me under Ubuntu 10.04.
> > The icon should be towards the end of your Digitizing toolbar. You need
> > to click on it and hold to see other shapes.
> > Cheers
> > Saber
> > On Wed, 2011-11-09 at 16:38 +1100, Noli Sicad wrote:
> >> This plugin seems not to work with Ubuntu 10.04.
> >> Yes, I checked in QGIS manage plugin. It installed by I could see the
> >> icon and the menu entry in QGIS.
> >> I created a new shapefile and I toogle to edit. No icons showing in
> >> the toolbar that resembled or look like this.
> >> http://underdark.wordpress.com/2011/10/21/easy-rectangles-circles-and-ellipses-in-qgis/
> >> Any instruction how to make it work in Ubuntu?
> >> Thanks.
> >> Noli
> >> On 10/22/11, Pavol Kapusta <pavol.kapusta at gmail.com> wrote:
> >> > Hello,
> >> > i would like to introduce you the new Rectangles ovals digitizing
> >> > plugin.
> >> > This plugin is available in QGIS Contributed Repository and after
> >> > installing creates three new objects in Digitizing toolbar: one
> >> > multifunction button with digitizing tools, one button for rotation of
> >> > rectangles or ovals and spinbox for changing of number of segments for
> >> > ovals. There are 6 digitizing tools: "Rectangle by extent", "Rectangle
> >> > from center", "Square from center", "Circle from center", "Ellipse by
> >> > extent", "Ellipse from center". Plugin is active only when you are
> >> > editing polygon layers. Tools, which have "from centre" in the name are
> >> > able of snapping (after defining in Snapping Options tab of Settings)
> >> > of the virtual center of feature.
> >> >   "Rotation tool" is functional after selection of (exactly) one
> >> > rectangle or oval.
> >> > After digitizing of feature, there is Feature form with possibility of
> >> > changing default attribute values.  You can deactivate this in Settings
> >> > -> Options -> Digitizing tab -> "Suppress attributes pop-up windows
> >> > after each created feature".  Option "Reuse last entered attribute
> >> > values" is not supported.
> >> > I hope you will find this tools useful.
> >> > Regards
> >> > Pavol
> >> > _______________________________________________
> >> > Qgis-user mailing list
> >> > Qgis-user at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
