[Qgis-user] Simplify?
Ramon Andiñach custard at westnet.com.au
Fri Nov 11 05:18:54 PST 2011
On 11/11/2011, at 20:40, "Chris Green" <chris.green at ibstv.co.uk> wrote:
> Hello
> I am using QGIS 1.7 in a Windows 7 environment. Everything seems great except for the simplify function (Vector->Geometry Tools->Simplify Geometries)
> I am trying to simplify an ESRI shape file which is around 95M. I have tried various tolerance settings, but although it looks like some simplification is taking place, actually the file is unchanged. So for example with tolerance setting of 1.0 I get an encouraging message that says:
> ‘There were 3638321 vertices in original dataset which were reduced to 559351 vertices after simplification’
> However after saving the changes to the layer, the dataset still looks identical to the un-simplified version and the file size remains unchanged at 95M. I have tried to simplify smaller shape files also, but with the same result.
> Can someone tell me what I am I doing wrong?
Hi Chris,
This is a guess...
I suppose your output file is different to your input file?
(otherwise windows will probably get confused)
-ramon.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111111/a311c217/attachment.html>
