[Qgis-user] Python bindings for SAGA for OSX (Leopard)?
Agustin Lobo alobolistas at gmail.com
Sat Nov 12 10:08:21 PST 2011
what about using saga through qgis? The plugin on linux seems to work
pretty well (Faunalia has performed some serious tests for a bunch of
modules). Would that not avoid the wxpython issue?
Agus
2011/11/12 William Kyngesburye <woklist at kyngchaos.com>:
> Well, it's looks like SAGA is going to be a tough one on OS X.
> One big issue for me is that it doesn't support wxPython (for the GUI) 2.9 yet.  2.9 is needed on Snow Leopard and Lion to make a fully-64bit SAGA.  But it should compile fine with a 32bit wxPython 2.8.  I just prefer to have things keep up with OS X.
> Configuration is strange - unlike all other configurations I've seen, SAGA configure does NOT detect or have any way to specify locations for dependent libraries and software, like wxPython, GDAL, PROJ, ...  It either expects libraries to be in standard system paths (/usr, /usr/local), or finds package config scripts (wx-config, gdal-config, ...) during compilation.
> This means adding stuff to your PATH to be able to find wxPython at all (the "official" distribution puts it in a subfolder of /usr/local/lib, so wx-config is not in the PATH) or any of my frameworks.  For those that don't have config scripts (ie PROJ), it will probably mean messing around with CFLAGS and LDFLAGS - I didn't get past the wxPython 2.9 problem to be able to try anything else.
> On Nov 10, 2011, at 11:26 AM, William Kyngesburye wrote:
>> After a quick look, I don't think the python version is a problem - there is no mention of a minimum Python.
>> SAGA has a lot of compiled C++, it's not just Python, so you need binaries or compile yourself.  wxPython is also required, for the GUI.
>> I can look into how to do the compilation on OS X, and may even make an installer package, though I support Leopard any more with my packages so you'd still have to compile it yourself.
>> On Nov 10, 2011, at 10:51 AM, Daniel Alejandro Pacheco wrote:
>>> Hi everythere,
>>> I am having some trouble in the moment when I want install some plugins that I need, in the beginning I thought that is because the plugins are broken, but later I understood that is because first, I need to install Phyton bindings for SAGA if I want run this plugins, the BIG problem is that in the webpage QGIS SAGA interface wiki I can´t find how to install it in Macintosh Leopard, I reviewed other tutorials, and in none mention the issue. My question is how can solve this problem?? I think that maybe I need update my version of Phyton to 2.6, because OSX Leopard has Phyton version 2.5, how can I do it? And I don´t know if this update solve this problem.
>>> Maybe someone can help me.
>>> Tks for you help
>>> Best Regards
>>> Daniel
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
>> - the wisdom of Tarzan
> The equator is so long, it could encircle the earth completely once.
