[Qgis-user] volume calculations in qgis
Saber Razmjooei
razmjooeis at faunalia.co.uk
Tue Nov 15 11:01:29 PST 2011
I had this problem in the past. Unfortunately there are not many plugins
for raster analysis in QGIS and I usually I end up doing in in GRASS.
The command in GRASS for inspection your raster layers, using polygon
vectors:
http://grass.osgeo.org/gdp/html_grass64/v.what.rast.html
You need to run r.null to set the unwanted values to null (i.e. positive
or negative values).
Cheers
Saber
On Tue, 2011-11-15 at 18:57 +0100, Bernhard Draeyer wrote:
> I have 2 high resolution raster DEM's before and after a recent flood
> event. The aim would be to get for different areas a) erosion/negative
> volumes b) accumulation/positive volumes and net volume.
> First of all, i subtracted the actual surface from the 'before'-surface
> to get a difference surface with positive (accumulation) and negative
> (erosion) values.
> Then i created a shape layer with polygons of different areas of
> interest. For each of them i need seperate volumetrics. Ideally, the
> polygons should contain in the end attribute values for accumulation,
> erosion and net volumes.
> Now i was looking without success for a well adapted method to solve my
> problem in QGIS or SAGA.
> How should i proceed? Is there any method in QGIS to sum up positive and
> negative raster values under polygons and put them in seperate attribute
> fields per polygon? Do i have to convert the raster in a point layer? I
> saw, that in esri's 3d analyst exist a tin polygon volume function, that
> covers this task. Does anything similar exist with an os gis?
> Many thanks for your help.
> Bernie
> Qgis-user mailing list
