[Qgis-user] Not-saving QGIS interface changes between restarts
jonathanmoules at warwickshire.gov.uk
Wed Nov 16 05:02:29 PST 2011
I'm looking to deploy QGIS into an enviroment with some very non-tech-savy
users. One of the things I'd like to do is stop any interface changes they
make from being saved between sessions, so that every time they start
QGIS, everything is in the same place.
The sorts of things I'm talking about are closing the layers panel, moving
toolbars around, etc.
Where does QGIS save these changes? And will QGIS work if I make that
location/file read-only?
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111116/7bb1a1a6/attachment.html>
