[Qgis-user] raster stats
Tim Sutton
lists at linfiniti.com
Sun Nov 20 02:57:22 PST 2011
Hi
On Sat, Nov 19, 2011 at 8:57 PM, John Callahan <john.callahan at udel.edu> wrote:
> Does anyone has information on the progress of this ticket? From reading
> the comments on the the ticket, it looks as though there are some
> possibilities for enhancement.
> I use rasters regularly so this issue comes quite often. For one particular
> 10GB DEM (in IMG format) it takes 7 or 8 minutes to calculate stats in QGIS,
> which takes a while when it happens every time I open that file. Stats have
> already been computed through gdalinfo. Thanks for any information.
> - John
This should no longer be an issue with recent changes I made. Please see:
http://hub.qgis.org/issues/3735
If you still get the issue, please let me know with detailed steps on
how to replicate.
Thanks
Tim
> On Thu, Apr 14, 2011 at 7:24 AM, Radim Blazek <radim.blazek at gmail.com>
> wrote:
>> New ticket http://trac.osgeo.org/qgis/ticket/3735
>> Radim
>> On Mon, Mar 21, 2011 at 4:37 PM, John Callahan <john.callahan at udel.edu>
>> wrote:
>> > I'm not sure if this behavior is expected or I am missing something.
>> > I have a 1 band raster dataset (an elevation DEM) in TIF format. It has
>> > statistics computed from "gdalinfo -stats mydata.tif" However, when I
>> > open
>> > it in QGIS (both 1.6 and 1.7 trunk), and look at the Metadata tab in
>> > Layer
>> > properties, there are two sections that contain band stats information.
>> > The
>> > first section is labeled "Band 1" and lists the same stats as found
>> > using
>> > gdalinfo. The second section is labeled "Band" and says "No stats
>> > collected
>> > yet" for band 1. QGIS has to create the stats when I apply a color map
>> > or
>> > stretch. For large rasters, this takes a while, and must be done each
>> > time
>> > it's used in QGIS.
>> > Has anyone experienced this behavior? Is this expected? Is there a way
>> > to
>> > let gdal compute all the stats that QGIS needs? Thanks.
>> > - John
>> > John Callahan, Research Scientist
>> > Delaware Geological Survey, University of Delaware
>> > URL: http://www.dgs.udel.edu
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
