[Qgis-user] No password for QGIS HUB
Rhys A.D. Stewart
rhys.stewart at gmail.com
Mon Nov 21 11:09:20 PST 2011
Hey,
Yeah man, already confirmed that I can login to other osgeo sites with
my userid.
So here is where its at:
on hub.qgis.org when I tried rhys it gave me the option to register that userid.
Did that with my email address and it said that the email was already
registered.
Found out that "rhys-stewart-gmail-com -" was the userid under which
my previous issues were recorded under.
went ahead with the hub registration of the userid "rhys" with a
slightly different email. (in gmail you can use a "." to create
different email addresses but they all go to the same inbox eg
rhys.ste.wart at gmail.com)
So i changed my password on osgeo.org and it changed my password on
hub.qgis.org.
So I guess technically I'm ok in that I can now log bugs/wishes etc.
It would be cool though if I could just reconcile everything back to
the rhys userID, i.e all the bugs/issues from the
"rhys-stewart-gmail-com -" userid...but there were only like 3 or 4
bugs/issues/fixes anyway, so I guess it'd be a lot to ask.
Thanks!!
Rhys
On Mon, Nov 21, 2011 at 1:09 PM, Werner Macho <werner.macho at gmail.com> wrote:
> Try to login with you osgeo id from the other sites..
> Am 21.11.2011 17:59 schrieb "Rhys A.D. Stewart" <rhys.stewart at gmail.com>:
>> Hey, I'm hub.qgis.org....
>> I can see issues/bugs that I've filed before under the user name
>> "rhys-stewart-gmail-com -". So it looks as if I was just ported over
>> as that. But I can still login to all other osgeo sites using the
>> userid "rhys".
>> On Mon, Nov 21, 2011 at 11:12 AM, Werner Macho <werner.macho at gmail.com>
>> wrote:
>> > May I ask you on which URL you are trying these?
>> > sounds like you are on the "I want to change my password" OSGEO URL -
>> > and
>> > not on hub.qgis.org
>> > regards
>> > Werner
>> > Am 21.11.2011 17:05, schrieb Rhys A.D. Stewart:
>> >> Hey,
>> >> That is what I thought, but when I enter my user name and password and
>> >> then hit enter it comes up with a form saying register, with all the
>> >> fields already populated. but then says that the email address is
>> >> already taken.
>> >> So this is where I am stuck.
>> >> Regards,
>> >> Rhys
>> >> On Mon, Nov 21, 2011 at 10:51 AM, Alexander Bruy
>> >> <alexander.bruy at gmail.com> wrote:
>> >>> Hi,
>> >>> you don't need new account because hub.qgis.org still use
>> >>> OSGeo ID's. So you should be able to log in with your old
>> >>> password and OSGeo ID.
>> >>> 2011/11/21 Rhys A.D. Stewart<rhys.stewart at gmail.com>:
>> >>>> Greetings!!
>> >>>> Was going to submit a bug report but then realized that the old trac
>> >>>> site has been replaced by another site @ hub.qgis.org.
>> >>>> Was trying to register and it appears that my info was ported over
>> >>>> from the old trac site, it says that my email address is already in
>> >>>> use and im seeing a user called "rhys-stewart-gmail-com -". But there
>> >>>> is no option to reset a password. And i cant register a new account
>> >>>> unless I use another email address. Any suggestions on where to go or
>> >>>> who to contact?
>> >>> Alexander Bruy
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> >> Qgis-user at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
