[Qgis-user] Scale bar problem
Giovanni Manghi
giovanni.manghi at gmail.com
Wed Nov 23 08:26:39 PST 2011
the scale bar is broken in 1.7.2. If you use Windows install qgis-dev
with osgeo4w.
Cheers
-- Giovanni --
On Wed, 2011-11-23 at 11:23 -0500, Gerardo Jimenez wrote:
> This problem is new to me, It did not happened in Quantum Gis 1.71
> I loaded a couple of raster images in EPSG 32614. I Checked the layer
> properties/General Tab and I can read that the CRS information is
> correct. When I change the project properties/CRS tab and change from
> EPSG 4326 to 32614, the scale bar do not change and shows 60,000
> degrees. The same when I change the properties using the globe Icon in
> the lower right corner. I tried loading a vector layer with the same
> crs (32614) and the same.
> I checked my OS regional settings and they are comma as thousands
> separator and point as decimal separator. I am using Qgis 1.72
> standallone on win732bits 4gb of RAM. I tested the same set of data in
> XP and in ubuntu 11.10 and all the show the same problem
> I have a Laptop with win732b 3gb of RAM and Qgis 1.71 and I do not see
> any problem
> Any help is welcome
> Gerardo Jiménez Delgado
> Instituto de Investigaciones Antropológicas
> Universidad Nacional Autónoma de México
> Ciudad Universitaria s/n
> Coyoacan 04510 Mexico City
> Mexico 56 22 95 16
> Qgis-user mailing list
