[Qgis-user] QGIS attribute table encoding
MORREALE Jean Roc
jr.morreale at enoreth.net
Sun Nov 27 03:41:59 PST 2011
Le 27/11/2011 12:22, Michal Zimmermann a écrit :
> Hi guys,
> my native language is Czech which uses signs like ě, š, č, ž etc. If you
> have a look at http://imageshack.us/photo/my-images/51/qgisencoding.png/,
> you'll see QGIS is having trouble displaying those signs right. Is there a
> way to get them right without manually rewriting each one of them? Like
> setting encoding to the whole dbf file? Shapefiles affected were previously
> opened with ArcGIS (with no problem) and probably were created with ArcGIS
> as well. If anyone comes up with a solution, please let me know.
When you add a new vector layer, there is a list which allows you to
select the charset to be used. It doesn't work if you drag'n drop your
file directly into qgis.
