[Qgis-user] announcing time series plot plugin (experimental)
Anita Graser anitagraser at gmx.at
Mon Nov 28 05:44:03 PST 2011
Hi Josef,
On Thu, Nov 24, 2011 at 8:34 AM, josef k <groundwatergis at gmail.com> wrote:
> Hi Anita,
> I am glad you find some use for it!
> I did choose SpatiaLite since I deal with quite a lot of data from several
> sites at the same time.
Are you using any of SpatiaLite's functions? Would it be difficult to
adjust the code so it could handle arbitrary vector data sources?
> It turned out that spaialite is a great data container for me and my
> colleagues since we only have to deal with one single (and portable) db
> file for each site. Furthermore, since we are mainly hydrogeologists and
> for sure no db gurus, spatialite seemed lika a much easier way to start
> organizing things than e.g. post-GIS.
There are some reasons why I don't use Spatialite much, e.g. the
combination of QGIS + Spatialite has some issues if you define database
views and try to import them into QGIS. The data types are screwed up
often, which in turn makes it impossible to visualize the features by their
(numerical) attributes.
Once PostGIS is set up, I've found it to be much more reliable and
predictable than Spatialite. e.g. Spatialite's weak typing lead to
unexpected results.
Therefore, I'd suggest implementing support for other vector formats
available in QGIS before building new features. A broader setup will
attract more interested users and possible developers.
Best wishes, keep up the good work!
Anita
> I also hope that I (or anyone else that finds it interesting) will get
> time to extend the plugin to include more ways of visualising other
> hydrogeo data from the same spatialite db. Additional functions would be
> stratigraphy plots (similar to ARPAT), time change visualisation  (as your
> Time Manager), gesection profiling, some R statistics etc. (Could be a
> lightweight alternative to the core functionality of ArcHydro GW data model
> and tools.)
> regards
> josef
> 2011/11/23 Anita Graser <anitagraser at gmx.at>
>> Looks great! I'd have quite a lot of use cases for such a plugin.
>> Any specific reason why it's limited to Spatialite as a data source?
>> Best wishes,
>> Anita
>> On Wed, Nov 23, 2011 at 10:18 PM, josef k <groundwatergis at gmail.com>wrote:
>>> Fellow QGIS-Users!
>>> I just finished my first QGIS python plugin in an experimental version.
>>> The plugin uses pyspatialite and matplotlib to load data from a sqlite
>>> database and plot it by matplotlib plot command. The intended use is for
>>> e.g. hydrogeologists (i.e. me) to quickly select features that corresponds
>>> to observation wells, stream gauges or other measuring stations with data
>>> to be plotted and then quickly (yes I am in a  hurry) have a window with
>>> time series plot for zooming, panning and visually examine the data (I know
>>> it is not very scientific but I do perform some serious data analysis at a
>>> later stage...).
>>> Anyway, the plugin is named TimeSeriesPlot, marked as experimental, and
>>> found in QGIS User-Contributed Python Plugin Repository.
>>> Screenshot:
>>> https://docs.google.com/open?id=0B1vhrFUx2OZBODQ5YjJjZjgtYzkyNC00NmQwLWFiYWQtNjkzYmE2MGY0MzY4
>>> Instructions are found in the readme.txt file shipped with the plugin.
>>> Download some sample sqlite data:
>>> https://docs.google.com/open?id=0B1vhrFUx2OZBNjExNDMwYTYtYWQzYi00YzVlLWI4M2ItNWM2NjZmYTAwNDU4
>>> And a (silent) video: http://www.youtube.com/watch?v=xqG5B780Q04
>>> Any feedback is appreciated!
>>> /joskal
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111128/bb8271cb/attachment.html>
