[Qgis-user] Scale bar on degrees with project CRS on ED50 UTM31
Agustin Lobo
alobolistas at gmail.com
Tue Nov 29 06:33:17 PST 2011
It works here (on ubuntu). It seems the only bug is just that the
units are not automatically set to
the units of the CRS.
Agus
2011/11/29 Otto Dassau <dassau at gbd-consult.de>:
> Hi,
> you could try to set Layer Units in menu Settings -> Project Properties ->
> General tab to Meters. Usually this should be done automatically, based on
> the units of the CRS you select. Maybe that doesn't work?
> Regards
> Otto
> Am Tue, 29 Nov 2011 09:13:48 -0500
> schrieb Gerardo Jimenez <gejst5 at hotmail.com>:
>> The same happened to me in a win stadnallone install on xp, vista and 7
>> and ubuntu. Main thing, scale bar seem not to work well on 1.72.
>> Nevertheless, I check if I coul use the measure tool and make a
>> reprojection of som layers in UTM wgs84 14N and both procedures work ok.
>> Then, Qgis recognizes my CRS, but the scale bar does not work. I get
>> around this by getting rid off the scale bar. Not a total solution but it
>> works. and the only thing is to get use to work without the scale bar in
>> the data frame.
>> Hope it helps
>> Gerardo Jiménez Delgado
>> Instituto de Investigaciones Antropológicas
>> Universidad Nacional Autónoma de México
>> Ciudad Universitaria s/n
>> Coyoacan 04510
>> Mexico City
>> Mexico
>> 56 22 95 16
>> > Date: Tue, 29 Nov 2011 07:51:27 +0100
>> > From: alobolistas at gmail.com
>> > To: qgis-user at lists.osgeo.org
>> > Subject: [Qgis-user] Scale bar on degrees with project CRS on ED50 UTM31
>> > Using 1.7.2, the scale bar is on degrees while project and
>> > layer CRS are projected. See screenshot here:
>> > https://sites.google.com/site/filestemp2/home/scalebar.jpeg?attredirects=0
>> > Agus
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
