[Qgis-user] Re: Import and open DBF tables in QGIS
Richard Duivenvoorde
rdmailings at duif.net
Tue Nov 29 12:57:19 PST 2011
On 2011-11-29 17:04, Timmie wrote:
>> you can, just use the "add vector layer" dialog.
> Thank you. That worked.
> But how do I convert data in the DBF into a point layer based on lat/lon columns?
You can try the XYtool-plugin. It is actually a plugin to fill x,y
columns in a dbf by clicking in a map, but in the menu of the plugin
there is the option to 'save as shapefile'. Doing this, you will be
asked which are the x and y column, and a name for the shapefile.
The shapefile is not immediatly loaded, you have to open it to see it.
Regards,
