[Qgis-user] WMS-T printing issue
bernhard.stroebl at jena.de bernhard.stroebl at jena.de
Tue Oct 11 07:11:38 PDT 2011
Hi Frederick,
I have this combination: geoserver (2.0.2) with gwc and
1) QGIS 1.7.0 on WinXP
2) QGIS 1.7.1 on OpenSuse
I access the WMS server with tiled=true and get several tilesets to
choose from in QGIS. As you use CutePDF I assume you are on a Windows
platform.
Tests (MapComposer with only tiled WMS layer, A0):
1)a) FreePDF: printing takes forever; killed after 40 minutes
1)b) QGIS' pdf button, print as raster ticked: crashes QGIS
2)a) print in pdf: works
2)b) QGIS' pdf button, print as raster ticked: works
so problem confirmed for WinXP
To Giovanni's response:
QGIS 1.7 does not have the option named but the dev-branch (aka 1.8 in
OSGEO-Install) has
geoserver with gwc is not recognized as a tiled WMS when connecting to
it, so the "tilesets" tab stays greyed out, however if you append
tiled=true to the WMS-server's URL the tiles are offered. Maybe this is
different if you run tilecache on your WMS-server
best wishes
Bernhard Ströbl
Am 11.10.2011 09:32, schrieb Frederick Löbig:
> Hi Giovanni,
> thanks for the quick response. This is exactly what I thought could be the issue. But there are a few things which I don't understand:
> 1. The map tiles are provided by a geoservers GWC. When I add the layer to e.g. uDig, the printing process works great. It's nice and fast (about 10 secs for ISO-A0).
> 2. I don't have the input-fields for width and height when I add a layer but I'm using qGIS 1.7.0 Wroclaw
> 3. Is it a general problem that qGIS is requesting a big tile instead of many small tiles when printing? If not, the problem has to be somewhere else...
> Has anyone had this problem with this software combination (qGIS 1.7 and GWC)?
> Best,
> Freddy
> B.Eng. Frederick Löbig
> Röderichstraße 59
> 60489 Frankfurt am Main
> E:: Frederick.Loebig at grunsnid.de
> P: +49 (0) 69 - 78 99 52 41
> M: +49 (0) 174 - 70 89 296
> Office:
> euNetworks GmbH
> Ludwig-Landmann-Straße 40560486 Frankfurt am MainP: +49 (0) 69 - 90 554 - 534
> E: Frederick.Loebig at eunetworks.com
> S: floebig
> This email and any attachments may contain confidential and/or legally privileged information. If you are not the intended recipient, please delete the email without reading it and notify the sender.
>> Subject: Re: [Qgis-user] WMS-T printing issue
>> From: giovanni.manghi at gmail.com
>> To: frederick.loebig at grunsnid.de
>> Date: Mon, 10 Oct 2011 22:29:00 +0100
>> CC: qgis-user at lists.osgeo.org
>> Hi Freddy,
>> many standard WMS servers do not allow to download images bigger than a
>> certain size, this is the reason why there are usually no problems to
>> create a large size layout on screen (because it is at 72dpi) but then
>> it results in a blank image when printing or exporting to pdf (at high
>> resolutions).
>> Since qgis 1.7 when connecting to a WMS server you can manually set the
>> maximum "tile" size to be requested. This allow to overcome the server
>> limits.
>> http://www.youtube.com/faunalia#p/a/u/1/0phOQD3wTAU
>> This option is not available (as it does not makes sense) when the
>> server is recognized as a tilecache one (the layers are shown in the
>> "tilesets" tab).
>> Cheers
>> -- Giovanni --
>> On Mon, 2011-10-10 at 13:40 +0200, Frederick Löbig wrote:
>>> Hi list,
>>> I have a major problem creating ISO-A0 size plots with QuantumGIS and
>>> a Tileset-layer.
>>> When I add the layer to the project with the ?tiled=true attribute,
>>> the navigation within the map-window is nice and fast and the look is
>>> really good. When I create plot-template and use an external pdf
>>> creator (CutePDF writer) it only works good for formats smaller or
>>> equal than ISO-A2. Any  plot of a bigger format results in an empty
>>> plot (at least the raster-layer isn't plotted, all added vector
>>> elements such as legend, northing, border etc. is plotted). I had a
>>> look at geoservers log to check for any errors resulting from
>>> insufficient memory or else with no result. Everything seems to have
>>> worked fine according to the log file.
>>> Has anyone had this kind of problem as well or does anybody have a
>>> workaround for that?
>>> Best,
>>> Freddy
>>> Röderichstraße 59
>>> Office:
>>> euNetworks GmbH
>>> S: floebig
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
