[Qgis-user] Creating Geological Maps
jonathanmoules at warwickshire.gov.uk jonathanmoules at warwickshire.gov.uk
Tue Oct 18 04:53:51 PDT 2011
Hi Gerhardus,
        Just to clarify on image file formats a little:
JPEG - Best used with photos. You're correct that it loses quality when
compressed. This is called "lossy compression".
PNG - Also commonly used with photos, the compression with this is
lossless, so you can set it as high as you like and no quality will be
lost.
Generally speaking while good for storing general imagery, the above two
formats don't typically hold spatial information so aren't used in a GIS.
TIF (also TIFF) - There's about a trillion different types of TIF file
format features. This is the file type that in the GIS world is commonly
used to store raster imagery. There are others, but this one is the most
supported, even if different aspects are supported by different
applications.
By default they're uncompressed, but they can be compressed using a number
of methods, LZW compression is a popular choice and is lossless. TIFs
themselves don't always store spatial information but may come with a
"world file" (tfw or tab format) which is a small text file which contains
that information. Some TIFs do store spatial information within the TIF
file itself and these are called "GeoTIFFs".
Some (geo)tiffs can also store "pyramids" - these make large rasters
display faster when zoomed out.
Hopefully that clears things up a little.
Regards,
Jonathan
From:   Gerhardus Geldenhuis <gerhardus.geldenhuis at gmail.com>
To:     tech at wildintellect.com
Cc:     qgis-user at lists.osgeo.org
Date:   16/10/2011 22:26
Subject:        Re: [Qgis-user] Creating Geological Maps
Sent by:        qgis-user-bounces at lists.osgeo.org
On Sun, Oct 16, 2011 at 10:03 PM, Alex Mandel <tech_dev at wildintellect.com>
wrote:
On 10/16/2011 01:32 PM, Gerhardus Geldenhuis wrote:
Just to check, do you have projection on-the-fly turned on? For best
image quality the image needs to be in it's native projection. Though in
this case it sounds like you just opened the image file to look at it.
How does it look in something like GIMP when you zoom in?
Hi Alex
Many thanks for the reply!
No idea if I have project on-the-fly turned on, I could not see any
reference to it in the project properties or options.
Native projection? I scanned the paper images and the scanner saved them
as jpeg files. I then opened up the images in The Gimp rotated
and aligned the to a drawing grid in Gimp because they were about 1 degree
skewed. I had pencilled lines on the paper that represented UTM grid
lines. I saved these as both jpg and png format both in lowest compression
thus highest quality. Viewing either the jpg or png file in Gimp or Image
Viewer is fine and if I zoom in to 1:1 scale the quality is perfect.
> Second question is how can I "align" this png file with with an actual
> co-ordinate system. I have marked 4 points on my paper maps and lines
> between these points that represent the UTM grid on which I worked and I
> would need to at least roughly align this image with the UTM grid.
Georeferencing plugin, this will turn your tiff into a GeoTiff, the same
as what you might get from preprocessed ASTER data. You can mark and
enter known coordinate locations and then warp the image to fit.
That sounds excellent I am going to try that now.
> Thirdly I am not sure how to draw on a new layer but still view my image
as
> a template for the digitizing.
> I am more than happy to read any documentation and work through
tutorials.
> What is lacking at the moment is the terminology to search for the
correct
> things and experience. I am working through a number of tutorials but
are
> still struggling a bit to connect A to B.
Read the manual on the QGIS website, create a new vector layer and
editing it can be over anything else you have loaded in the map view.
http://qgis.org/en/documentation/manuals.html
> I will eventually add some ASTER imagery but it is my understanding that
> these are in tiff format and contains extra information like spatial
> referencing. I suspect that if I can master the above then adding ASTER
> imagery will be easy.
> Lastly is there any geological map symbol databases available?
It's been discussed and some work has been done on it but nothing
comprehensive yet. If you have Images or Fonts of the symbols you want
you can easily convert them for use in QGIS.
A shame, I have send of an email to the British Geological Survey and see
what they come back with. I might have access to the ArcGIS and could load
the images database provided by the US Geological Survey. Not sure if
ArcGIS would allow me to export it into something more usable. My google
results turned up an email thread which suggested that there was some work
done on supporting gdb files...
Regards
Gerhardus Geldenhuis_______________________________________________
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111018/307c6284/attachment.html>
