FW: [Qgis-user] qgis-web-client: searching, but how?
Nelson nelsonjsilva at simplesnet.pt
Tue Oct 18 12:33:12 PDT 2011
Andreas,
I have the same problem.
A few days a go, I send you a message. Ignore that. Tomorrow I will try
again with this orientation.
Perhaps Pirmin can give us more information about option b)?
Thank you both.
nelson
-----Mensagem original-----
De: qgis-user-bounces at lists.osgeo.org
[mailto:qgis-user-bounces at lists.osgeo.org] Em nome de Andreas Neumann
Enviada: terça-feira, 18 de Outubro de 2011 19:47
Para: qgis-user at lists.osgeo.org
Assunto: Re: [Qgis-user] qgis-web-client: searching, but how?
Hi Arichp,
I am sorry - I am currently traveling (and attending a conference).
We need to better document this, but there are basically two ways
(probably more).
Either through:
a) wsgi python script on the server (typically querying Postgis tables)
b) through QGIS server (Sourcepole implemented something I am not yet
too familiar with)
In version a) this is quite disconnected from the project itself, e.g.
addresses, parcel numbers, street names, etc. - that are present
regardless of the other topics in the project.
Version b) is actually using data layers from within the project, as I
understand it - you basically work with the FILTER and SELECTION command
of QGIS server.
Version a) and b) can also be combined.
For version a) you'd have to define a table with a structure like the
following:
CREATE TABLE av_user.suchtabelle
  searchstring text,
  displaytext text NOT NULL,
  search_category text,
  the_geom geometry,
  geometry_type text,
  searchstring_tsvector tsvector,
  CONSTRAINT suchtabelle_pkey PRIMARY KEY (displaytext)
WITH (
  OIDS=FALSE
CREATE INDEX in_av_user_searchstring_tsvector_gin
  ON av_user.suchtabelle
  USING gin
  (searchstring_tsvector);
and fill the table with the data you want to search in. Then get the
wsgi to work whicht will query the database.
When you type in the searchbox it will query the database for search
strings that are longer than 1 character. It will then list all options
while you are typing. After selecting one of the result records in the
combobox it will get the actual wkt geometry from the python script,
zoom to the geometry, and highlight it.
Hope this at least helps to understand the mechanism.
I understand that the documentation is not yet ideal. I will try to
improve that when I am back from my traveling.
Andreas
> Step by step, maybe?
> Regards,
> Arichp
> Qgis-user mailing list
