[Qgis-user] how to display longitude and latitude
Agustin Lobo alobolistas at gmail.com
Sun Oct 23 03:18:08 PDT 2011
You can use the Coordinate Capture plugin also.
Nevertheless, this is an improvement requested long time ago: Coordinates should
be displayed in the Coordinates window at the bottom of the display
both in the current CRS
and in Geographic Lon,Lat WGS84 (in other words, as the Coordinate
Capture plugin does,
but the Coordinate Capture requires you to click on Start Capture and
then click on each position
again (which makes sense for a capture) while the requested feature
would be continuous).
Agus
2011/10/23 Ramon Andiñach <custard at westnet.com.au>:
> On 23/10/2011, at 12:48, Severino Salmo <sgsalmoiii at yahoo.com> wrote:
> Hi all,
> I have a simple question. I want to display the longitude and latitude in
> the x- and y- axes for my area of interest. I tried to look at the QGIS
> manual but I cant find the steps how to do it. Any help and comments will be
> greatly appreciated. Thank you very much.
> Hi Sev,
> Question.  Where are you trying to get the latitude and longitude to
> display?
> If it's in the Print Composer, then start with the project CRS set to
> projection that uses latitude and longitude, e.g. WGS84.
> -ramon.
> Qgis-user mailing list
