[Qgis-user] warper for vector layers?
Agustin Lobo alobolistas at gmail.com
Tue Oct 25 01:33:03 PDT 2011
Does the current raster georeferencer output the parameters used for
the warping? A fast solution would getting
trying on a raster layer first and then using the affine
transformation plugin with the same parameters.
Agus
El día 25 de octubre de 2011 10:06, Germán Carrillo
<carrillo.german at gmail.com> escribió:
> Hi Agustin,
> if I understood well, you would need the Affine transformation plugin,
> anyway, the current implementation ask you to include the transformation
> parameters, so you need to do some calculations on your own before.
> Regards,
> Germán
> 2011/10/25 G. Allegri <giohappy at gmail.com>
>> I don't think Qgis has vector warping tools. The Georeferencer plugin
>> manages only raster data, and for its polynomial transformations based on
>> GCPs use GDAL directly, which itself implements warping for rasters only.
>> I think that writing a warping plugin for vectors woudn't be too hard, but
>> it's not what you were looking for ;)
>> giovanni
>> 2011/10/25 Agustin Lobo <alobolistas at gmail.com>
>>> Hi!
>>> We have a vector layer that has been digitized over a raster with
>>> wrong settings (wrong pixel resolution).
>>> Is there any way to correct the geometry of the vector layer by
>>> defining control points with the new coordinates and apply
>>> a warping in qgis?
>>> Agus
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>   |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/
