[Qgis-user] problems with georeferencing results
Richard Duivenvoorde rdmailings at duif.net
Tue Oct 25 11:10:46 PDT 2011
On 2011-10-25 19:04, G. Allegri wrote:
> Here it is the GCP list picture: http://bit.ly/suh5UL
> (I wonder why ths srcY coordinates are shown as negative values)
What is projection of your raster, is it really epsg:3003 (to be tested
with 'gdalinfo yourraster'.)
Is there maybe a tfw file hanging around which determines another extent
four your source raster? If seen this behaviour recently while using the
plugin.
Try to set your tiff aside from other files, create a fresh epsg:23032
project with 'on the fly' and try again?
Hope this helps.
Regards,
