[Qgis-user] Double line Feature
Matej Mailing
mailing at tam.si
Tue Oct 25 11:48:27 PDT 2011
This is almost it! :-)
Now we get a lot of polygons - is it possible to combine all the polygons
into one object (so that there are no "borders" inside it)?
Thanks,
Matej
2011/10/25 Albin Blaschka <albin.blaschka at standortsanalyse.net>
> Am 25.10.2011 13:52, schrieb Matej Mailing:
> Basically we need this to define some sort of "protected area" (for
>> example, 30 cm in both sides from the cable) along some
>> telecommunication network cables (mainly optical) and therefore I don't
>> think only the representation would be sufficient. Probably some plugin
>> that would create polygon with a centralized line that we are "snapping
>> to" and with defined area (width) would be even better than just two
>> lines, because this way we could define some color of fill of that
>> closed "part" around cable in our projects for example. Hopefully I
>> explained it enough clearly, if you need more information, please let me
>> know :-)
> Hello!
> That sounds like you need a buffer :-)
> In QGIS, you find this functionality under Vector (fTools plugin) ->
> Geoprocessing (or similar, I have just the german version at hand at the
> moment...)
> Albin
> | Albin Blaschka, Mag.rer.nat.
> | Etrichstrasse 26, A-5020 Salzburg
> | * www.albinblaschka.info * www.thinkanimal.info *
> | - It's hard to live in the mountains, hard but not hopeless!
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111025/105e22a1/attachment.html>
