[Qgis-user] OS X Lion - Experiences?
Mars Sjoden
marsofearth at gmail.com
Sat Oct 29 16:36:25 PDT 2011
Some curious findings just now after reviewing several hours of Screen
recordings of using QGIS on various operating system platforms (eyes...
bleeding)...
What I noticed...
1. Double click layer to Launch Properties Window
2. (do nothing or make changes) Simply single click APPLY/OK and QGIS
crashes
VS
1. RIGHT CLICK layer,
2. Select Properties from contextual menu to launch Properties Window
4. Do what ever you like then click APPLY/OK...
5. no problem
I repeated this test about 10 times on OS X.6.8 cleaned caches and new
.plist file and the new QGIS 1.7.1-2 from William Kyng's site, with these
exact same outcomes as above.
However, after about the 10th relaunch of QGIS 1.7.1-2 after crashing it,
I was unable to reproduce (no crashes) after about 30+ properties toggles
and 10+ different QGIS relaunches.
Now (to add another variable). After I completed
1. launch QGIS
2. Load Natural Earth shp layer
3. Double Click Natural Earth shp layer to Launch Properties Window
4. (do nothing) Simply single click APPLY/OK and QGIS
5. OK
6. Scroll mouse zoom map canvas
7. Double Click Natural Earth shp layer to Launch Properties Window
8. (do nothing) Simply single click APPLY/OK and QGIS crashes
and returns back to
1. launch QGIS
4. (do nothing) Simply single click APPLY/OK and QGIS crashes
Soooo far I am unable to crash QGIS IF I invoke the Properties Window via
Right Mouse click on Layer.
could this be the key to my issues? I hope so... will ONLY use right
click layer to invoke properties window from now on to test.
mars
On Sat, Oct 29, 2011 at 3:10 PM, Mars Sjoden <marsofearth at gmail.com> wrote:
> Yah, I am wondering if there is a certain hardware configuration on my
> machines that is not agreeing with Qt cocoa.
> Apple hardware tested:
> 3x iMac 3.06ghz core2duo, NVIDIA GeForce 8800 GS
> 1x iMac 2.00ghz core2dou, ATI radeon hd2400
> 1x macbookpro 2ghz, core dou, ati radeon???
> recent testing on:10.6 vanilla
> QGIS 1.7 to 1.7.1-2 (and 1.8) - including William Kyng's required
> frameworks
> opening Properties dialogue windo and selecting OK or APPLY (either after
> making changes or making no changes) will at some point seemingly randomly
> crash QGIS
> With the latest 10.6.8 update (or perhaps 1.7.1 not sure which came first)
> I have one iMac 3ghz machine that will kill QGIS everytime I open a
> properties window and click OK or APPLY without making any changes.
> Just curious if there is some sort of hardware issue since I have flat out
> re-installed 10.6 on many of my machines with the only extra software
> installed including QGIS and the frameworks and still have the same issue.
> Of note,
> I have tested the latest operating systems from
> OSGeo (ubuntu 11?)
> Fedora 15
> Mint 11, Katya
> Debian 6 Squeeze
> OpenSUSE 11
> and Windows 7
> both on separate partition tables without a virtual machine and in
> Virtual Box, Parallels 7 and VMWare 4.
> I still have instability issues, although found OpenSUSE 11 and Windows 7
> to be the most stable so far allowing for up to an hours worth of work
> before a crash.
> The crashes in OpenSUSE 11 seem to be related to the properties dialogue
> window OK/APPLY (that is when the crashes occur), while on Windows 7 it is
> more random through out the use of QGIS.
> Datasets I have been testing with have been from the openly available
> Natural Earth shapefile datasets as you suggested William.
> Mars
>> What sort of problems are you having? I don't think there is anything
>> specific to a system version, it's more connected with what Qt version and
>> type (carbon vs. cocoa). Newer systems need Qt cocoa, definitely Lion does.
>> There are a few known issues, with bug reports and mentioned in my
>> distribution readme (font selection, non-ascii chars in GRASS shell, max #
>> open files). A couple other recent issues I can think of: odd
>> georeferencer window behavior, minimized globe plugin panel appears on top
>> of upper-left corner toolbar.
>> Much of this probably has something to do with Qt cocoa.
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "Oh, look, I seem to have fallen down a deep, dark hole. Now what does
>> that remind me of? Ah, yes - life."
>> - Marvin
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111029/143fc5dc/attachment.html>
