[Qgis-user] OS X Lion - Experiences?
Mars marsofearth at gmail.com
Sat Oct 29 22:31:08 PDT 2011
Yes, I have sent quite a few crash reports, but would like to build QGIS with debugging to hopefully get more useful info for dev.'s or others better at understanding how I am stuffing things up.
I am hopeful that I may have pin-pointed more consistently QGIS crashing.
They Mac model I was using is iMac8,1 The other iMac I have been using is an iMac7,1
Sent from my iPhone
On 2011-10-29, at 4:51 PM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> I couldn't get QGIS to crash like this, on either Snow Leopard or Lion.
> Maybe a crash report will help.
> On Oct 29, 2011, at 6:36 PM, Mars Sjoden wrote:
>> Some curious findings just now after reviewing several hours of Screen recordings of using QGIS on various operating system platforms (eyes... bleeding)...
>> What I noticed...
>> 1. Double click layer to Launch Properties Window
>> 2. (do nothing or make changes) Simply single click APPLY/OK and QGIS crashes
>> VS
>> 1. RIGHT CLICK  layer,
>> 2. Select Properties from contextual menu to launch Properties Window
>> 4. Do what ever you like then click APPLY/OK...
>> 5. no problem
>> I repeated this test about 10 times on OS X.6.8 cleaned caches and new .plist file and the new QGIS 1.7.1-2 from William Kyng's site, with these exact same outcomes as above.
>> However, after about the 10th relaunch of QGIS 1.7.1-2 after crashing it,  I was unable to reproduce (no crashes) after about 30+ properties toggles and 10+ different QGIS relaunches.
>> Now (to add another variable). After I completed
>> 1. launch QGIS
>> 2. Load Natural Earth shp layer
>> 3. Double Click Natural Earth shp layer to Launch Properties Window
>> 4. (do nothing) Simply single click APPLY/OK and QGIS
>> 5. OK
>> 6. Scroll mouse zoom map canvas
>> 7. Double Click Natural Earth shp layer to Launch Properties Window
>> 8. (do nothing) Simply single click APPLY/OK and QGIS crashes
>> and returns back to
>> 1. launch QGIS
>> 4. (do nothing) Simply single click APPLY/OK and QGIS crashes
>> Soooo far I am unable to crash QGIS IF I invoke the Properties Window via Right Mouse click on Layer.
>>   could this be the key to my issues?  I hope so... will ONLY use right click layer to invoke properties window from now on to test.
>> mars
>> On Sat, Oct 29, 2011 at 3:10 PM, Mars Sjoden <marsofearth at gmail.com> wrote:
>> Yah, I am wondering if there is a certain hardware configuration on my machines that is not agreeing with Qt cocoa.
>> Apple hardware tested:
>> 3x iMac 3.06ghz core2duo, NVIDIA GeForce 8800 GS
>> 1x iMac 2.00ghz core2dou, ATI radeon hd2400
>> 1x macbookpro 2ghz, core dou, ati radeon???
>> recent testing on:10.6 vanilla
>> QGIS 1.7 to 1.7.1-2 (and 1.8)  - including William Kyng's required frameworks
>> opening Properties dialogue windo and selecting OK or APPLY (either after making changes or making no changes) will at some point seemingly randomly crash QGIS
>> With the latest 10.6.8 update (or perhaps 1.7.1 not sure which came first) I have one iMac 3ghz machine that will kill QGIS everytime I open a properties window and click OK or APPLY without making any changes.
>> Just curious if there is some sort of hardware issue since I have flat out re-installed 10.6 on many of my machines with the only extra software installed including QGIS and the frameworks and still have the same issue.
>> Of note,
>> I have tested the latest operating systems from
>> OSGeo (ubuntu 11?)
>> Fedora 15
>> Mint 11, Katya
>> Debian 6 Squeeze
>> OpenSUSE 11
>> and Windows 7
>> both on separate partition tables without a virtual machine and in Virtual Box, Parallels 7 and VMWare 4.
>> I still have instability issues, although found OpenSUSE 11 and Windows 7 to be the most stable so far allowing for up to an hours worth of work before a crash.
>> The crashes in OpenSUSE 11 seem to be related to the properties dialogue window OK/APPLY (that is when the crashes occur), while on Windows 7 it is more random through out the use of QGIS.
>> Datasets I have been testing with have been from the openly available Natural Earth shapefile datasets as you suggested William.
>> Mars
>> What sort of problems are you having?  I don't think there is anything specific to a system version, it's more connected with what Qt version and type (carbon vs. cocoa).  Newer systems need Qt cocoa, definitely Lion does.
>> There are a few known issues, with bug reports and mentioned in my distribution readme (font selection, non-ascii chars in GRASS shell, max # open files).  A couple other recent issues I can think of: odd georeferencer window behavior, minimized globe plugin panel appears on top of upper-left corner toolbar.
>> Much of this probably has something to do with Qt cocoa.
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "Oh, look, I seem to have fallen down a deep, dark hole.  Now what does that remind me of?  Ah, yes - life."
>> - Marvin
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> "This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
