[Qgis-user] Having trouble with prj-Files produced by QGIS
Robert Nuske rnuske at gwdg.de
Mon Sep 5 07:38:43 PDT 2011
Hi
Shapefiles written with QGIS were not displayed correctly in other GIS and
caused problems with ogr2ogr (reprojected points were shifted approximately
180m).
Searching for a probable culprit I looked into different ways to reproject
shapefiles, single coordinates and different prj-files. Finally comparing
prj-Files produced by QGIS (Saving as... Shapefile or processing with fTools)
with prj-files constructed by ogr2ogr and prj-files downloaded from
spatialreference.org. Examples for two coordinate reference systems are
attached, formatted to enhance the readability.
Looking at those examples and some documentation on the web, I started to
believe that the part --DATUM["D_unknown",-- in QGIS' prj-file could cause
problems. In contrast to the first parameter/name of PROJCS and GEOGCS, the
name of the DATUM seems to be a key that has to match an entry in a list of
known datums and "D_unknown" was not found in that list.
Replacing QGIS' prj-file with prj-files of the same EPSG-Code from
spatialreference.org led of course to a successful reprojection of the
shapefile and correct placement of the points in various GIS.
Using QGIS 1.7 and gdal 1.8.0 form ubuntugis_unstable on Ubuntu 10.10.
So I am wondering: what did I do to mess up the prj-files so badly?
Any Hints?
cheers,
  robert
PS: Is there any reason that the proj4-strings in QGIS (as shown in
Settings/Project Properties/CRS) differ from the ones in PostGIS and
spatialreference.org. QGIS seems to prefer +towgs84 instead of +datum.
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110905/7379fc27/attachment.zip>
