[Qgis-user] Home Range calculation using Kernel density
Giovanni Manghi giovanni.manghi at gmail.com
Wed Sep 7 00:25:37 PDT 2011
if you are windows user installing all the pieces (QGIS + R + a bunch of
R libraries) can be tricky, so have a look at this screencast that shows
how do do that
http://ubuntuone.com/p/zon/
remember that in QGIS you have also a "triangulation" plugin, that
allows you to calculate animal fixes given operator locations and
bearings.
See also the QGIS wiki page on this matter
http://www.qgis.org/wiki/HomeRange_plugin
cheers
-- Giovanni --
On Tue, 2011-09-06 at 15:43 -0700, antie66 wrote:
> I recently discovered it is possible to conduct home-range analyses in QGIS
> using R through Python and I am desperately trying to find a way to analyse
> my data (locational data from a baboon troop, available in shapefile, .csv,
> .gpx file or whatever file it takes). I want to analyse my data using a
> fixed kernel density using a plug-in method (as proposed by Sheather & Jones
> (1991) and described in detail in Section 3.6 of Wand & Jones (1995)). I've
> tried using the 'dpik' function in the 'KernSmooth' package in R directly,
> but I am too inexperienced too make it work (very frustrating!).
> Can anybody let me know whether this would be possible in QGIS, before I
> start the what sounds like a difficult download process?
> Many thanks for any advice offered.
> Louise
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Home-Range-calculation-using-Kernel-density-tp6765962p6765962.html
> Sent from the qgis-user mailing list archive at Nabble.com.
> Qgis-user mailing list
