[Qgis-user] Problems with r.in.gdal
José Carlos Guerrero Antúnez jcgantunez at gmail.com
Fri Sep 9 12:53:40 PDT 2011
i'm using MacOSX, Snow Leopard 10.6.8, Qgis 1.7.3 and I think I have
updated all
frameworks from KyngChaos Qgis Download page.
And I want to import a raster esri ".adf" using r.in.gdal, and this is the
message:
r.in.gdal -o
input=/Users/joseca_IMac/Desktop/Altitud_Worldclim/alt/alt_30s_esri/alt/alt/w001001.adf
output=w001001g
ERROR 1: dlopen(/Library/Application
Support/GDAL/1.8/PlugIns/gdal_PDF.dylib, 1): Library not loaded:
/Library/Frameworks/FreeType.framework/Versions/2.4/FreeType
Referenced from: /Library/Application
Reason: Incompatible library version: gdal_PDF.dylib requires version 14.0.0
or later, but FreeType provides version 13.0.0
Over-riding projection check
G_set_window(): Illegal latitude for North
Finalizado con error
And I'm not a skilled user in programming.
Someone can help me or tell me how to proceed to fix this problem.
Best regards,
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110909/7c5109c8/attachment.html>
