[Qgis-user] object labels
Nathan Woodrow madmanwoo at gmail.com
Tue Sep 13 00:15:38 PDT 2011
Hi Janneke,
It's not possible in the current build as my changes haven't been merged in
yet.  I have run it pass a few of the devs and they are happy with the
progress so far, it's just a matter of me cleaning a few things up once I
get the chance.
If you are able compile your own qgis version on windows (or other) you can
get the code for my patch at
https://github.com/NathanW2/Quantum-GIS/tree/expression-labels
I welcome any feedback you have if you are able to test it for me.
- Nathan
On Tue, Sep 13, 2011 at 4:44 PM, Janneke Qgis <janneke.qgis at gmail.com>wrote:
>  Dear Nathan,
> is it already possible to use expression based labels, and if so, how can
> we get it? If you need someone to do some testing on Windows we're happy to
> do that.
> Janneke
> On 28/07/2011 09:09, Nathan Woodrow wrote:
> My upcoming patch that adds expression based labels will be able
> to achieve this once it's completed;  I'm just cleaning up the UI and
> testing everything then I will get the guys to merge it in.  Until then you
> will need to create a new column.
>  - Nathan
> On Wed, Jul 27, 2011 at 9:15 PM, Torsten Lange <tlange at gwdg.de> wrote:
>> Ok, thank you, Andreas!
>> Torsten
>> Am Mittwoch 27 Juli 2011, 11:00:01 schrieb Andreas Neumann:
>>  >  Hi,
>> >  Currently, you have to create a new column. I usually create a view in
>> >  Postgis for this purpose.
>> >  It is in on the wishlist that one can create a "virtual" column - not
>> >  only for labeling, but also for map tips and perhaps symbolization.
>> >  Until then you have to do it yourself.
>> >  Andreas
>> >  On Tue, 26 Jul 2011 22:51:34 +0200, Torsten Lange wrote:
>> > > Hi,
>> > > Is there a way just to print - lets say - the first four letters of a
>> > > objects
>> > > name? Or must I create a new row for that?
>> > > Thank you, Torsten
>> > > _______________________________________________
>> > > Qgis-user mailing list
>> > > Qgis-user at lists.osgeo.org
>> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110913/a0a368b8/attachment.html>
