[Qgis-user] Profile Tool
Alister Hood alister.hood at synergine.com
Wed Sep 14 03:27:07 PDT 2011
Yes, I learned it on the list - there are plugins with other Python
dependencies that need to be installed the same way.
For anyone else doing it, I forgot to mention that it only works if you
use an installer built for the same version of Python that QGIS uses
i.e. an installer for Python 2.6 or 3 will not work with Python 2.5.
Sent: Wednesday, 14 September 2011 10:01 p.m.
To: Alister Hood
Cc: qgis-user at lists.osgeo.org; david.fawcett at gmail.com;
garcia.silva at gmail.com
Subject: Re: [Qgis-user] Profile Tool
On 01/09/2011 01:18, Alister Hood wrote:
	Hi guys,
	You can manually extract the files from the shapely installer
(using
	e.g. Izarc or 7zip, or possibly just by renaming it as .zip or
	something), and put them in the right places.
	You need to put the shapely folder (from inside PURELIB) in e.g.
	C:\OSGeo4W\apps\Python25\Lib\site-packages\, and the geos.dll
and
	libgeos-3-2-2.dll in I think C:\OSGeo4W\bin, although instead of
	installing those I seem to have got it working by editing
	C:\OSGeo4W\apps\Python25\Lib\site-packages\shapely\geos.py to
use the
	lib from OSGeo4W instead (C:\OSGeo4W\bin\geos_c.dll).
Hi Alister:
Your trick to unzip and manually place shapely 1.2 into the
python\site_packages\ dir worked fine. Many thanks.
Micha
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110914/96ec1fff/attachment.html>
