[Qgis-user] Re: [Qgis-developer] DB Manager release
Giuseppe Sucameli sucameli at faunalia.it
Fri Sep 16 07:08:28 PDT 2011
Hi Christian,
On Fri, Sep 16, 2011 at 1:25 PM, Christian Röttger
<chris.roettger at web.de> wrote:
> i got an error when connecting to the database
I fixed it right now, try DB Manager v0.1.1
> but seems to be very cool,
> greets christian
> below the error log
> Fehler bei der Ausführung von Python-Code:
> Traceback (most recent call last):
>  File "/home/chris/.qgis/python/plugins/db_manager/db_manager.py", line 72,
> in itemChanged
>    self.refreshTabs()
>  File "/home/chris/.qgis/python/plugins/db_manager/db_manager.py", line 109,
> in refreshTabs
>    self.info.showInfo( item, True ) # force refresh
>  File "/home/chris/.qgis/python/plugins/db_manager/info_viewer.py", line 62,
> in showInfo
>    self._showTableInfo(item)
>  File "/home/chris/.qgis/python/plugins/db_manager/info_viewer.py", line 90,
> in _showTableInfo
>    html += table.info().toHtml()
>  File
> "/home/chris/.qgis/python/plugins/db_manager/db_plugins/info_model.py", line
> 352, in toHtml
>    ret = self.getTableInfo()
>  File
> "/home/chris/.qgis/python/plugins/db_manager/db_plugins/postgis/info_model.py",
> line 156, in getTableInfo
>    ret = TableInfo.getTableInfo(self)
>  File
> 292, in getTableInfo
>    spatial_info = self.spatialInfo()
>  File
> line 173, in spatialInfo
>    return VectorTableInfo.spatialInfo(self)
>  File
> 381, in spatialInfo
>    extent =
> self.table.database().connector.getTableEstimatedExtent(self.table.geomColumn,
> self.table.name, self.table.schema().name if self.table.schema() else None)
>  File
> "/home/chris/.qgis/python/plugins/db_manager/db_plugins/postgis/connector.py",
> line 452, in getTableEstimatedExtent
>    self._execute(c, sql)
>  File
> line 658, in _execute
>    raise DbError(e, sql)
>  File "/home/chris/.qgis/python/plugins/db_manager/db_plugins/plugin.py",
> line 47, in __init__
>    self.msg = unicode( errormsg )
> UnicodeDecodeError: 'ascii' codec can't decode byte 0xc2 in position 26:
> ordinal not in range(128)
> Python-Version:
> 2.7.1+ (r271:86832, Apr 11 2011, 18:30:20)
> [GCC 4.5.2]
> QGIS-Version:
> 1.7.0-Wroclaw Wroclaw, exported
> Python-Pfad: ['/usr/share/qgis/python', '/home/chris/.qgis/python',
> '/home/chris/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
> '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
> '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL',
> '/usr/lib/pymodules/python2.7/gtk-2.0',
> '/usr/lib/python2.7/dist-packages/gst-0.10',
> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
> '/usr/lib/pymodules/python2.7/libubuntuone',
> '/usr/lib/pymodules/python2.7/ubuntuone-control-panel',
> '/usr/lib/pymodules/python2.7/ubuntuone-client',
> '/usr/lib/pymodules/python2.7/ubuntuone-storage-protocol',
> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
> '/home/chris/.qgis/python/plugins/mmqgis/forms',
> '/home/chris/.qgis/python/plugins/fTools/tools',
> '/home/chris/.qgis/python/plugins/mmqgis/forms']
> Qgis-user mailing list
Giuseppe Sucameli
